DIY compressor with cheapo from HF and 1 gallon tank from Ebay
Old Jan 17, 2021 | 09:33 PM
Discorama's Avatar
Default DIY compressor with cheapo from HF and 1 gallon tank from Ebay
First I modified the compressor from Harbor Freight: got rid of all the useless plastic trims, removed the switch and fuse holder (using a 16A switch for 30A was a bad idea anyway), installed a barb fitting for the air input and made it watertight. The 1 gallon tank from Ebay got a 100/70psi pressure switch and is filled through the flexible leader hose with integrated check valve. Tank and compressor (with 4 rubber isolators) were mounted on an aluminum base plate. The whole thing fits nicely into the SLS compressor bay (I will use a longer hose to get the air intake above the worst case waterline):
Finally I got it installed today.
Old Jan 17, 2021 | 10:15 PM
greisinb's Avatar
Cool. Any thoughts on mounting up a simple rock shield for the tank?
Old Jan 17, 2021 | 11:34 PM
Discorama's Avatar
The tank sits quite high. First I would damage the rocker panel if I went over too big rocks.
Old Jan 18, 2021 | 12:08 AM
greisinb's Avatar
I haven’t poked around too much on that area of the truck but I guess I was thinking more along the lines of stones kicking up there at highway speeds.
Old Jan 18, 2021 | 01:17 AM
Discorama's Avatar
The tank is quite sturdy, typically they are made out of 10 gauge steel. I wouldn't expect damage if some small stones hit it other than exposing the bare metal. Otherwise parts like mufflers wouldn't last that long. To better protect it against corrosion is a good idea though, maybe I should spray it with some heavy duty bedliner.
Old Jan 18, 2021 | 04:21 AM
The Deputy's Avatar
Turned out nice.
Old Jan 18, 2021 | 02:48 PM
Chris59's Avatar
Looks really clean.
Thinking about doing the same - any reason you used the hf pump instead of the viar? They seem pretty similar. How much time does having that tank save you when filling tires?
How is it wired?
Old Jan 18, 2021 | 03:33 PM
Discorama's Avatar
Simply because I had the hf pump already and it fits. The tank allows me to fill it while driving and I have pressure right away when I stop. Most time is saved, because I don't have to unpack it, connect it to the battery, move it around, and let it cool down after use before I can stow it away. I run a awg10 wire into the engine compartment where it is connected via a relay to the aux battery.
Old Jan 19, 2021 | 02:29 PM
greisinb's Avatar
That makes sense to me, now that you mention it. I am about to explore adding compressor and this has me thinking quite a bit- I love it.
Old Jan 19, 2021 | 02:46 PM
whowa004's Avatar
I have a small arb mounded in the engine bay above pass wheel well. It's a little more protected in there and shorter wiring lengths. Just something to consider, though this write up looks to be very well done!
