Do everyone's Disco2 breaks suck this bad?
Old Oct 24, 2009 | 11:14 PM
oysterhead's Avatar
if you don't plan to off-road, don't buy the Tom Woods. It's overkill, and you may have vibrations at high speeds (75+ mph).
Old Oct 25, 2009 | 12:47 PM
Your truck weights as much as a killer wale, it ain't gonna stop quick.
Old Oct 25, 2009 | 02:14 PM
Don't let the dealer bleed your brakes, do it your self and learn what makes you truck tick.
3 to 4 pints of DOT 4 brake fluid and 2 feet of 5/16" hose and your set, all for under $20.
Old Oct 25, 2009 | 02:44 PM
discoboy's Avatar
I notice the brake feel on my 2000 D2 is very different from my 2003 D2. I tried to bleed already, maybe changing out the front pads and rotors when needed will change the feel, just my .02
Old Oct 25, 2009 | 03:01 PM
Rover_Hokie's Avatar
I test drove my 01 D2 from private party and thought is was great but a lot of pedal travel. So it was a long distance purchase so test drove on Monday, and was in that area for business, so did the deal and had the local dealer check out the soft pedal. Result first/last dealer trip new brakes and rotors, same soft pedal. I did later bleed them myself and added Valvoline Synth brake fluid. Still a lot of travel from what I am use to on other vehicles, but stops well, and on the second pump tightens up.
I have heard from some that D2's are like that, but not sure what else to do. They do stop me well though.
Old Oct 25, 2009 | 03:18 PM
Baylink's Avatar
I may well have my mech check the vacuum boost; the symptoms are starting to feel familiar to me, and they feel like a vacuum leak on the booster.
Old Dec 13, 2009 | 03:57 PM
Baylink's Avatar
And as my other thread explains, no, it apparently isn't the master or booster after all...
Old Dec 13, 2009 | 04:03 PM
JoMar's Avatar
I am thoroughly impressed with my brakes. Dual piston up front stops my truck amazingly fast.
Bleeding is fun, as others have said do it yourself.
Old Dec 13, 2009 | 04:17 PM
Mrmerlin's Avatar
you can buy the 3 spicer greaseable U joints for the front drive shaft it takes about 2 hours total from jack up to ready to run
Old Dec 13, 2009 | 06:19 PM
Baylink's Avatar
If that was to me: I just cast about on Craigs, and found someone who had an already-rebuilt one with zerks and all, bought it for $100.
