do i have to remove the whole center console to get at the bolt under the shift lever
No, Just use a small screwdriver, or nail file, to pop off the insert on top of the shifter. Inside of it, you will clearly see the nut that needs to be tightened. If your shifter is "loose" then more than likely the nut will have completely unscrewed itself and you'll need a pair of tweezers to fish it out so you can reset it. Use a pair of needle nose pliers to tighten it.
orion27
11-06-2008 08:16 AM
davecason
01-27-2008 07:38 PM
sna77
07-10-2007 06:02 PM
