Do I need Springs and Shocks?
Old Sep 26, 2009 | 11:28 PM
mattrickman's Avatar
Default Do I need Springs and Shocks?
Wife's 95 D1. Shocks are shot. This one isn't taken off-road much (at least any real off-roading). Can I just replace the shocks or should I do shocks and springs (do the springs wear out?)
thanks
Old Sep 27, 2009 | 12:06 AM
sloppyjoe's Avatar
you can just replace the shocks, but it is kind of a band aid. if you have the coin do the springs also. the truck will ride better with a matched pair of shocks and springs vs. a set of worn springs and new shocks
Old Sep 27, 2009 | 12:43 AM
NiveK1970's Avatar
ya at that age the springs are probably pretty well worn out
Old Sep 27, 2009 | 09:34 AM
petedisco96's Avatar
If the back has sagged/dropped new springs do alot more than shocks.
Old Sep 27, 2009 | 09:40 AM
Both your shocks and coils should be replace, especially if you will be keeping it awhile and want a much better ride.
Consider buying one of the OME medium lifts from, http://www.lucky8llc.com/Search.asp?Manu=OME for a great replacement and probably the best price around.
Old Sep 27, 2009 | 11:14 AM
Thanks all.. That is what I kind of figured. I have the OME setup on my other disco. Was trying to save some $$ to put into my disco .
Mike - Is there anywhere in Denver that sells (and stocks) OME for Land Rovers?
fri3daz3
Aug 18, 2008 09:22 PM
grrRover
Mar 21, 2008 06:24 PM
andrewmcoffin
Feb 19, 2008 10:53 AM
adowgiert
Dec 10, 2007 08:15 PM
bklahl
Aug 15, 2007 08:19 AM
