does the 03-04 disco hav any problems i should worry about?
Old Feb 14, 2010 | 12:52 AM
LRDalltheway77's Avatar
Default does the 03-04 disco hav any problems i should worry about?
wonderign if the 03-04 disco has an problems?
Old Feb 14, 2010 | 06:56 AM
meltdowndave's Avatar
Oil pump failures are extremely common on '03s. There is a TSB that establishes the VIN range most likely to be affected.
That being said, oil pumps fail outside the VIN range and some '04s have failed as well.
To be clear, the issue is not the oil pump, itself. Rather, the block was mismachined and the front cover that houses the pump gears does not align correctly placing the gears under stress. Thus, the gears fail prematurely.
The only demonstrated fix is a new block as per Land Rover. People are experimenting around with DIY fixes but it's anyone's guess if they'll work over the long run.
Other concerns are head gaskets, which tend to go around 75k. Spark plug wires also don't hold up well and should be replaced around 60k.
Old Feb 14, 2010 | 07:07 AM
d2luvr's Avatar
And the big one-you must rebuild/replace the front drive shaft before it puts a hole in the side of your transmission.
Old Feb 14, 2010 | 07:26 AM
discoklein's Avatar
d2luvr, where did you get your front driveshaft rebuilt at, I am here in Osceola and have 2 disco's both needing the front shafts rebuilt...
Old Feb 14, 2010 | 08:37 AM
Read through the "write up" section, click the links and get educated before you buy.
Old Feb 14, 2010 | 09:06 AM
d2luvr's Avatar
discoklein PM'd you. By the way, does Art still have the drag strip open?
FightOnUSC79
Mar 10, 2011 09:44 AM
charrliy525
Jul 9, 2009 10:49 PM
Camjurgz
Jan 4, 2009 08:57 PM
Pads Fan
Apr 29, 2008 04:03 PM
Boogieman
May 13, 2007 08:01 AM
