Does this mean bad valves? Picture!
I'm having persistent misfires on 4 6 and 7 and have reason to suspect the valves. But I removed the intake to swap coils and my wife noticed that the 4 6 and 7 intake tubes were clean. No way I cleaned three and left five dirty. Could this be bent intake valves?
That picture isn't great. But 4 6 and 7 tunes are clean. All of the rest have old oil on them. Since my valve covers don't vent to the intake anymore, something has cleaned those tubes. If the intake valves don't seat properly, then exhaust gas and or gas could be cleaning them.
ANY other theories?
I'm asking because I am about to swap the heads. But if there is a better theory I'm all over it because I'd rather save the head gaskets and work if something else might work.
ANY other theories?
I'm doing that now as I work my way down. I recall, a few days ago, turning the engine and seeing the rockers move on all cylinders but I'm getting that desperate feeling after having tried so many things. I'll try them all again. I'll just pull the fuel pump relay and turn it over. But if I smell gas in those tubes from lingering pressure Ill think the valves may be screwed.
Maybe there is something wrong with the lobe grind and the intake valves on 4 6&7 are closing to late and you are pushing some of the fresh charge back into the intake washing the intake runners clean?
Are you sure your timing chain marks are correct, not a tooth off?
Which bore did you bend the rod on?
Number 8 had the bent rod and broken piston. It has good compression now.
I also filled the cylinders with antifreeze (from removing the heads) the level hasn't dropped in any of them for an hour.
Stumped.
I'm going to be so pissed if it is the cam.
I'm positive about the timing chain. I turned the crank sixteen revolutions and made sure that the marks were perfect each time, before I put the cover on.
