Door lock actuator, dont buy a new one
Old Jan 9, 2009 | 06:25 PM
NW_rockhound's Avatar
Default RE: Door lock actuator, dont buy a new one
Does this repair work on D2's? My lock actuators are really, really slow to move and require the unlock button to be pushed several times.
Also, sounds like the actuators need to be opened on a seam and and are not screwed shut. How doI re-assemble/seal these?
Thanks, David
Old Feb 23, 2010 | 05:46 AM
Goncho's Avatar
4th Gear
Smile How to Install Lock Actuator on '03 Disco?
Can someone help me find info on how to replace the driver rear door actuator on my '03 Disco? Thanks. Goncho
Old Mar 10, 2010 | 10:21 AM
csanchez's Avatar
3rd Gear
Will that work on an 2006 Range Rover's passenger door (Front)? Thanks.
Old Apr 3, 2010 | 12:37 PM
bigjerel's Avatar
Same story here. My front passenger door lock stopped working. Removed the door panel, mirror, frame and the actuator (the white plastic piece that connects the rod to the door handle pops open so you can slide the rod out once you open it...took a little bit of fiddling around to figure that out) from the vehicle and was able to open the actuator and get to the motor. The D2 apparently isn't as easy as the D1 to get the motor out, but what I have is a small dc motor with the numbers 20005 and 3C1562 stamped on it from Johnson (electric I presume). Has anyone found this particular motor before and if so where can I purchase it or a replacement one that will fit? Or, where can I get new or used one with a warranty for a decent price? I looked at roverland and they didn't have any for the D2. If I could figure out how to upload pics I would put some up for everyone who has the same questions as I did. Thanks, Jere
Old Apr 3, 2010 | 01:25 PM
Mark G's Avatar
You might have to fabricate that part from scratch. If it's plastic, go to Walmart and buy a $2 plastic cutting board ad cut and dremill. You'll have plenty left over for downstream projects.
Old Jul 17, 2010 | 01:57 PM
salmaneid's Avatar
Default Door Actuator DC Motor
Dear Guys..
Well, No more worries about the DC motor as I have them brand new for sale at GBP20+Shipping. it has the golden worm gear so just plug n play and save lot of time n money..if anyone interested then email me on Landroverbh@gmail.com
Regards..
Salman EiD
Old May 21, 2011 | 05:02 PM
tstkrosser4's Avatar
please.....someone......how do you open (pry open) the actuator motor?
Old May 24, 2011 | 04:18 PM
mtlman8's Avatar
Default 2000 p38 door lock ??????
Hi all, I'm new to the forum and I have an issue.I just replaced the remote for my truck and it wont sync. when I put the key in and turn it no lights come on and nothing happens. when I'm inside and push down the lock it doesn't lock all the doors. whats the issue? any help will be greatly appreciated.
Old Mar 8, 2013 | 03:47 AM
dailyman12001's Avatar
Default disco door actuators
I have just bought a actuator direct from china for my 98 disco, it is i direct replacement for the landrover one, even comes with modification kit if required for £2.60 = £280 postage it fits straight onto the mounting plate and requires two cable connectors to fit to the LR plug.
12V Universal 2 Wire Power Car Door Lock Actuator 360c | eBay
hope this helps all who have this problem.
Old Mar 11, 2013 | 09:45 PM
RYAN3326's Avatar
Great tip. Thanks
