Door Sill and Lower B pillar trim
Old Apr 4, 2015 | 03:30 PM
cybercop's Avatar
Default Door Sill and Lower B pillar trim
Anyone know how to remove these. I have pryed as hard as I dared on the plastic door sill and it will not come loose. Cannot find any screws holding it.
Same with the lower B-Pillar trim.
Any ideas?
Old Apr 4, 2015 | 03:49 PM
cybercop's Avatar
Nevermind. Figured it out.
Dusty, you can delete if you want.
Old Apr 4, 2015 | 03:56 PM
OffroadFrance's Avatar
Any ideas?
When you say "plastic door sill" I assume the long sill from the front to the rear doors below both doors. If it's this one I believe you push the center pip of the plastic rivet inwars and pry the sill off gently.
Bearmach Land Rover Discovery 2 Sill Trim Plastic Retaining Clips x 10 79086L | eBay
the rivets appear to be total loss items so you'll need new ones.
LAND ROVER DISCOVERY 2 TD5 PAIR OF PLASTIC SILL COVERS | eBay
Old Apr 4, 2015 | 09:48 PM
cybercop's Avatar
No, I was talking about the "threshold" that holds down the carpet at the side.
Figured out that there was a strip running down the middle of it that you pop off to expose the screws.
Twins Disco
Dec 16, 2013 01:50 PM
0304Disco
Oct 29, 2013 10:32 AM
We-go-up
Aug 5, 2013 07:13 PM
ralphobell
Apr 1, 2013 11:09 AM
gtokid
Oct 11, 2007 12:03 PM
