Draing and refill old brake fluid
Old Oct 30, 2007 | 11:23 AM
RamblingMan's Avatar
Default Draing and refill old brake fluid
I've never done this before, just bled the lines but Discomike recommended changing it so now I'm stuck: do I start with the wheel furthest away and just pump while I keep the reservior full until clean fluid comes out.
Or do I open all four bleeders, pump away and keep reservoir filled until clean oil comes out from all 4 bleeders. Then follow this with a bleed procedure on each wheel?
RM
Old Oct 30, 2007 | 12:07 PM
okdiscoguy's Avatar
Default RE: Draing and refill old brake fluid
use a turkey baster to take all of the fluid out of the reservoir. Put new fluid in, and following the bleed procedure, pump each line until you have clean fluid coming out. I think you can cycle the ABS pump by holding the pedal for 30 seconds on each line.....
Old Oct 30, 2007 | 12:27 PM
Exactly, could take as much as 2 quarts.
varlean
Freelander
Dec 18, 2011 09:30 AM
discomedic4
Apr 9, 2010 07:59 PM
hazletbassist89
Nov 3, 2008 06:44 PM
chakadog
Sep 21, 2008 04:27 PM
union7
Freelander
Oct 9, 2007 12:33 PM
