Drill frame holes
Drill frame holes
A post that I read on Expedition Portal suggested that D2 owners should "Drill some holes in the bottom of the rear frame rails to allow drainage and avoid the rot problem which develops there."
Never heard that one before. Anybody have any thoughts on this?
If so, I wonder specifically where holes should be drilled?
DustyLBottoms (01-14-2015)
IMO waxoyl then let it set (cold weather is better) and then fill with closed cell polyurethane foam to stick to the waxoyl. Maybe this would cut out any capillary ingress. Might be worth an experiment on some old chassis (frame) parts. I think I know just the man for that on the Pajero website. he's a bit of a techie
