drilled or drilled & slotted rotors
What exactly are drilled or slotted rotors going to do for a truck, other than wear out brake pads faster and make more dust?
I have them on my track car, and can't tell the difference when driving it on the street. Even when I'm driving it way harder than anyone ought to be driving a 2.5 ton 4 wheel drive truck. The only time they make a noticeable difference is when I'm getting close to brake fade (on the track, with very hard track pads).
I got new rotors and ceramic pads all the way around and the price was relatively good, but I opted for solid rotors for the braking power: Brake Rotors Discs Pads Brakes Cross Drilled & Slotted
the short answer is - they are not necessary 99% of the time today because most brake pads do not have problems with off-gassing.
I agree. The only reason they are run on the track is that a lot of the very hard track pads (the ones that barely work at all when cold) have a gassing problem once they start getting very hot. Which is why I run them on the track car but nothing else.
Here's some kit:
04 2004 Land Rover Discovery Brake Rotor - Brake - Brembo, PBR, Pilenga, Beck Arnley, Pronto, Rear, Front - PartsGeek
EBC kits: 04 2004 Land Rover Discovery Brake Rotor Set - Brake - EBC, Front, Rear - PartsGeek
Drilled and slotted rotors are for escape of gas and dust but have reduced friction surface and reduced mass, which in turn reduces the rotor's ability to absorb heat (which is how it works, by turning force into heat).
Drilled rotors collect mud and don't shed it. Slotted or dimpled rotors are better for mud as they hold less of it.
Vented rotors are far better than either slotted or drilled rotors without venting, for the street. Vented rotors are probably very poor for mud deep enough to encase them.
Although Partsgeek advertises vented rotors for the Land Rover, I don't see how they can make them fit in the stock calipers unless the rotor surfaces are very thin. The mass would also necessarily be reduced which is not good. You really want a much thicker vented rotor to allow sufficient mass and still provide vent space, but this means a wider caliper.
At the end of the day, they don't really make racing brakes for Discoveries because they're for off-road where you use low gear and engine braking, not so much wheel brakes. For the street, there's the Range Rover: http://www.roverparts.com/Parts/BRM03.cfm
