Driver' floor dampness
Been monitoring some dampness on my new to me 04 Disco. Seems to only gather (and I use that term lightly) on the driver's side near the sill (see attached pic). If I drag and blot a white paper towel I can get some evidence of seeming slick slightly pinkish (very slight) fluid. Looked around and been watching fluid levels. I suspect coolant, but don't see how it could possibly gather at this location. Thoughts?
Cheers, Lawndart
Cheers, Lawndart
Thanks guys.
The coolant is pinkish. No noted change in level.
I checked the drains from underneath - all seemed fine
Passenger side is dry
History -
I purchased this D2 from a Land Rover dealer. 1 owner, less than 40k miles, Texas vehicle. This think looks virtually new (inside, outside under hood and underneath). Think the core could be leaking? How would the fluid migrate to the driver's side only?
History -
Flush and change coolant to get rid of pink (dexcool or similar) and go to the green color coolant. Do not mix coolant colors, do not believe in 100,000 mile coolants. Will save the rest of the engine and cooling system. Drains below should be dripping AC condensate if running while parked with AC on. Here's map of cooling system. PITA to do heater core, dash is built around it. Can be bypassed with a loop of hose for testing. Coolant flows thru the heater core whenever truck is running, not just when heat is on.
Also look around the throttle body heater plate, not sure how coolant could leak there and migrate along a hose or cable, but it is on the driver's side of the truck. Can also be bypassed in warm weather for testing, it prevents ice up of throttle under 36F.
Do not try radiator stopz leakz. It can clog rest of cooling system and you will overheat and need new radiator, perhaps damage engine. Pix of radiator with dexcool "sludge" that collects in the bottom rows, reducing cooling ability. Add stop leak and it becomes "concrete".
I did check the condensation drains and fairly certain I noted two small spots on the ground from these drains; been nice weather lately and I am not a hug fan of AC until it is really hot.
I do have plans to rid the system of Dexcool this spring.
I guess the search continues. A bad heater core at less than 40k kinda blows my mind; fingers crossed.
Seems to me the location of the dampness is a low point.
I see no easy way of lifting the carpet on the driver's side - suggestions?
It is the corrosive nature of the coolant when it is combined with other coolant. Bubba at the quick oil change place thought he was helping by topping off the fluids, etc. Chemical reactions are faster with heat, but continue with the truck parked and in storage. So it is years, not miles. But coolant lines to core are on other side, it may not be the O-rings, may just be a bad core. The RAVE manual has pages about removing interior trim, etc.
DiscoRover007
07-06-2011 10:28 PM
