Driver Turn Signals On Solid
I have a 2001 Disco2 with about 110k. The other day I noticed that the 3 driver turn indicators were on solid. Later they went off but must have come on again during the night and drained the battery. My first thought was a shorted Atlantic British trailer wiring module. I disconnected it and all seemed fine again. About 4 hours later, the driver turns came on solid again.
So now, I need to keep a 13mm wrench handy and disconnect the battery when I shut it off to make sure it does not drain. Of course, I cannot lock it now. Then the other day I went to turn the key and dead as a doornail, which was odd since the battery was disconnected. I hooked up a jump pack and it started.
I searched the forum and saw many posts ...
1. The Atlantic British trailer wiring module causes electrical problems?
2. A weak battery causes odd behavior with the alarm?
3. Alarm ECU could be fried?
Here is the kicker ... I am trying to sell this truck! It is not worth a crap if it has electrical gremlins, so I would like to fix it without spending a fortune. Has anyone else had this exact problem and how did you fix it?
2004FXD
10-23-2007 07:54 AM
