Driver window
Old Aug 15, 2007 | 01:20 PM
ajh's Avatar
ajh
Default RE: Driver window
Why would you suggest a water soluable grease for this application vs one that will stay on when it gets wet like Moly?
Old Aug 15, 2007 | 01:21 PM
Blatallic's Avatar
Thanks for the advise ad tips....Wonder how much time Im going to take on this LOL...
Is there any easier way in placing the white clips on the door panel....A few came off the red clips there on...Looks like they snap back in place...
Old Aug 16, 2007 | 09:30 AM
Blatallic's Avatar
Okay I installed everything,.....BUT the window only goes up half way...Could have they sent me a rear part instead of a front...this is really frustrating...
Old Aug 16, 2007 | 10:09 AM
98roverguy's Avatar
ORIGINAL: ajh
Lihium grease is not water soluble and is a very common application for window mechanisms. http://en.wikipedia.org/wiki/Lithium_grease
Old Aug 16, 2007 | 10:11 AM
98roverguy's Avatar
ORIGINAL: Blatallic
They may have. Is there a way you can compare your old one to the new one and see if they are similar?
Old Aug 16, 2007 | 12:46 PM
Blatallic's Avatar
They looked the same...actually they sent me the passenger front door....Go-figure lol....
Now im in a delima cause they wont accept the park back since I lubed it all up...lol....
I ordered the front left one so It'll be here saturday...
Old Aug 16, 2007 | 02:45 PM
okdiscoguy's Avatar
Someone on here might need one. If not, put it on E-bay.
Old Aug 16, 2007 | 02:50 PM
Blatallic's Avatar
So true....I'll be putting it for sale as soon as I get the correct one....
Old Aug 16, 2007 | 03:09 PM
98roverguy's Avatar
ORIGINAL: Blatallic
Geeze what a pain and they should take it back anyway cause they caused the problem in the first place. Lousy service imo. Wheredid you order from?
Old Aug 16, 2007 | 09:30 PM
sfxgamer's Avatar
Same thing happened to me after a little research I found the plastic washer at lowes. a package of 4-6 for 99 cents! I don't remember the size of the washer but if you bring the plastic thats broken off to lowes try and match it up. The one i bought was a little smaller so I threw 2 of them on the oven and when they were hot enough to bend, I bent them over the spot where they go. you need to stack 2 together so they keep the thickness and bam! 99 cent fix when land rover wants you to spend over 200.
