Driveshaft
Old Oct 2, 2019 | 07:57 PM
landroverdude's Avatar
Default Driveshaft
Hey guys I have one of the heavy duty great basin rovers front driveshafts to install and don't know if I should go to a mechanic or not, is it really just as easy as unbolting 8 bolts taking it out and then screwing it back in?
Old Oct 2, 2019 | 09:50 PM
Frank4's Avatar
It’s that easy. Got for it.
Old Oct 3, 2019 | 05:49 AM
JUKE179r's Avatar
Easy peasy and make sure you install it correctly... double cardan end attached at transfer case.
Old Oct 3, 2019 | 10:36 AM
boston4's Avatar
Looking at doing this this weekend as well. Do you just use a 9/16 socket and wrench, or do you need a special tool? I saw Lucky8 has a special driveshaft removal tool on their website but I didn't buy it because pricing seemed exorbitant.
Old Oct 3, 2019 | 10:38 AM
whowa004's Avatar
special tool is not necessary but did make it a little easier as it's thinner to ensure solid engagement on the nut (if I remember correctly)
Old Oct 3, 2019 | 02:08 PM
Richard Gallant's Avatar
A long extension will work. I blocked my rear tires jacked up the front so the front tire was just off the ground then rotated the tire with my foot to get the socket set. Use a wrench on another nut to lock it in place.
It took me a whole hour, including greasing and a test drive.
Old Oct 3, 2019 | 03:31 PM
Have it and love it fits in nice and tight and makes getting at the nuts with my impact a breeze.
Old Oct 3, 2019 | 04:04 PM
boston4's Avatar
As far as procedure, here's what I'd planned:
1. Chock back wheels, leave transmission in neutral, parking brake engaged
2. Jack up passenger front wheel and fit axle stand
3. Remove 8 bolts, rotating passenger front wheel as necessary to gain access to all nuts at differential side
4. Refit new part with replacement hardware as supplied
Old Oct 5, 2019 | 07:45 AM
cvhyatt's Avatar
Very easy. I am an IT geek with little mechanical ability and was able to swap it out in short order. Good luck!
Rover144
Mar 20, 2015 11:58 AM
acg
Jul 7, 2013 07:26 PM
TRIARII
Apr 11, 2013 05:25 AM
DaveBFoto
Mar 1, 2011 08:28 AM
GARovee
Mar 7, 2010 03:28 PM
