Driveshaft Double Cardan "H" joint damaged beyond use?
Old Dec 16, 2012 | 07:12 PM
CANAMDiscovery's Avatar
Default Driveshaft Double Cardan "H" joint damaged beyond use?
I took the time to dismantle the driveshaft today... Rented a U press from O'reilly's and it came apart pretty easily.
Noticed after giving all the parts a good cleaning some serious wear on the U joint sleeves on the double cardan... see pics.
The 2 close up pics are of two different sleeves...opposite one another on the cardan and would be holding the same U Joint. I bought this shaft as a rebuilt a couple years ago to replace my original shaft. Now I assume that this U joint probably failed and caused this damage?...was rebuilt and sold to me?
Is this a little too much wear to use the joint?
Attached Thumbnails Driveshaft Double Cardan "H" joint damaged beyond use?-img_0213.jpg   Driveshaft Double Cardan "H" joint damaged beyond use?-img_0214.jpg   Driveshaft Double Cardan "H" joint damaged beyond use?-img_0215.jpg
Old Dec 17, 2012 | 07:21 AM
jeffh's Avatar
yes... I would most certainly not put this back into my truck.
Old Dec 17, 2012 | 07:46 AM
drowssap's Avatar
time to find another one
Old Dec 17, 2012 | 09:43 AM
Most HD drive shaft on the market is from Great Basins Rovers in Salt Lake City.
You might call Bill and let him tell you the differences between his 2 shafts and everyone else.
Old Dec 17, 2012 | 10:45 AM
lr2001silver's Avatar
Banned
I can get one out to you asap!
Old Dec 17, 2012 | 12:20 PM
Lr2001silver...
Just sent you a message.
Guessing I will not regret getting one of your drive shafts by what people are saying on the site.
Brett
Old Dec 17, 2012 | 12:46 PM
ZGPhoto's Avatar
Originally Posted by CANAMDiscovery
Lr2001silver...
Brett
You'll love it!
Old Dec 17, 2012 | 12:56 PM
Banned
Thank you all for the support! I look at and respect you all like family. Just glad to be able to help when I can!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 19, 2012 | 04:37 AM
sickws6's Avatar
Its fine, press your joints in and install it. Bet you will never have an issue.
Old Dec 19, 2012 | 09:22 AM
Banned
How long have you been working on drive trains? And will you cover his transmission when it does fail?
