Driveshaft temperature...2002 D2
Has anyone monitored their drive shaft "temperature" with a laser temp gun...to see if it's getting hot.? I went for a 20 minute drive and then took the temps. The transmission was about 120 F, the front driveshaft cardan joint was 115F. The rear shaft at the rubber coupling was about 85f....The cats were in the area of 400F. The engine was at operating temp...
Seems to me that the front and rear driveshafts are not heating up substantially...
Comments?
Comments?
The following 2 users liked this post by redwhitekat:
anbran (09-04-2021),
Sandman614 (09-04-2021)
Really?!...Not at all....I had the shaft lubed about 1000 km ago..(.At least they said they did...) Its got those needle type grease fittings, so I've learned that many places don't have that type of grease needle.
This bit about the temperature check...was just for interest.
I've never had a failure...
Probably best to lube it myself...
hilltoppersx
ROAMING WITH FRIENDS
10-12-2009 10:37 AM
