Drivshaft? What is the aweful banging noise?
So I pulled the plug on the transfer case and hardly anything came out.. Just enough fluid, pitch black and gummed up to cover the bottom of a small bucket I put underneath... The Plug was caked with black sludge...
Found no metal shavings on the bottom drain plug, but I did find 2 very small shavings on the magnetic fill plug..
In the picture, I have already wiped most of the sludge off to look at it. Thats about 20% of what was originallys caked on there...
I'm going to fill it up and pray I haven't destroyed it... What type is best for the warm weather of the south, and can I use teflon tape to seal the drain plug??
I switched my transfer case over to 85w-140. You can also just run 85w-90.
Did you ever get a hot transmission light on the dash??? You should have, maybe I need to go back and read your earlier threads..
OE Gear Oil is 75W-90 & 85W-90 is fine. 75W-140 works well too.
I'm NOT a fan of using Teflon tape to seal the drain plug.
I only use Permatex 59214 (small tube) or 59235 (larger) and you can get it at any auto parts store. Works great.
> https://www.permatex.com/products/th...hread-sealant/
You "might" be able to save the TC with fluid, but with the issues you described I'd be sourcing a replacement just in case. I'd go with 85/140w for your situation as it apparently has a pretty bad leak somewherw to be that low on fluid.
Add it & take it for a test drive, but I'm pretty sure some bearings have been without proper lubrication for a while now.
Fluids are filled and no metal shavings on the drain plug, so hopefully its not lost...
Take a test drive & report back.
Fluid change to the TC changed nothing.. It's almost like a constant whinning noise now.. Only heard one really loud chirp noise.. no grinding noise that I could tell
I think its the Transmission fluid.. will let it cool off first and drain it...
If I drain the trans, how much should come out?? not all of it obviously becuase of whats in the Torque Converter wont drain out.. So how much should I expect to see??
Thanks
Thanks
Trainsmission drained out over a full gallon, or just over 4 quarts... It had a steady stream all the way till the end...
So i drained and filled the TC
the transmission was not low
I drained and replaced the rear diff fluid..
The whinning noise does not start until the truck has been driven a mile or so.. Whatever is whinning waits until it is hot/warm from road travel..
I have noticed that when it starts whinning, if i lightly press on the gas to basically nuetalize the pressure on the gears, the noise quiets some..
So we've gone from that clunking/banging to a whine? A D1/D2 transfer case isn't 100% quiet & gear whine is normal (lucky thats all the bone dry TC is making now) also letting on/off the gas can cause a clunk as it's trying to take up the speeds from both the front/rear diff and there is driveline slack which causes a slight clunk when you go on/off the gas
I let a friend drive one of my D2's and his driving style made it constantly clunk as he was on off the gas rather roughly. I got back behind the wheel and it never clunked for me.
I'm going to re-install the front driveshaft and remove the rear today to see if that changes anything..
