Drop down running boards?
Old Mar 28, 2016 | 06:32 PM
jamieb's Avatar
Default Drop down running boards?
Neighbor has a jacked up pickup. Opens the door, running boards drop down. Close the door they come up and hide.
I searched these online for Discos and nothing came back. Anyone use these to help wives, mothers, grandmothers get into the truck?
Old Mar 28, 2016 | 11:09 PM
LR03NJ's Avatar
WOW! you need hydraulics. It is possible though. But you have to modify it to your wanting. There is another term for that that they use for lifts which look like shock absorbers.
Old Mar 28, 2016 | 11:28 PM
Joemamma1954's Avatar
My son had them on his dually with 6" lift and 38" tires. It was much needed.
Old Mar 28, 2016 | 11:41 PM
LR03NJ's Avatar
Now I remember, you can use a linear actuator and for a small unit it can lift up to 350 pounds of weight. Easy way to do it is to mount n weld a slide rail on both ends and let the actuator push the side step outside when needed. Actuators vary in the amount of travel you need, If you want it to retract/fold under the chassis, you have to design a scissor type linkage to hold the step,
Old Mar 29, 2016 | 06:29 AM
jamieb's Avatar
This is what I'm talking about. Not sure if anyone uses them on Discos.
Old Mar 29, 2016 | 07:16 AM
I would think on a lifted disco while they would make entry easier but they are likely to be really expensive trail trash.
BMF175
Jan 22, 2023 12:54 PM
adam123
Mar 23, 2011 07:56 PM
LR3angler
Jan 8, 2007 06:25 PM
ZAD329
Feb 25, 2006 05:35 PM
