Drop Links for Sway Bar - When to replace them?
Old Jul 15, 2009 | 01:16 PM
04BluDisco's Avatar
Default Drop Links for Sway Bar - When to replace them?
Looking under the rig the other day, looked like they were leaking slowly what little grease they have in the drop arms, and it's leaking a bit... seeing that greasy look that tends to pick up dusts and grime...
I am not thinking there is too much of a noticeable performance difference, but when to replace them?
Old Jul 15, 2009 | 02:46 PM
Chrisinhouston's Avatar
I wouldn't think they are a high wear item like a ball joint or tie rod end so they may not need replacing unless something is broken like a rubber sleeve or they get bent. On the other hand if you are going to go ahead and replace them and are interested in greater wheel articulation on trials you might want to get these, I just ordered them last week when they were on a 40% off sale:
http://store.hicountryoffroad.com/Di...nect_p_18.html
Old Jul 15, 2009 | 03:05 PM
04BluDisco's Avatar
Nice set up.... what kind of shocks (besides silver) are you running on there...
Old Jul 16, 2009 | 05:36 PM
Urban Panzer's Avatar
MM, never seen those disconnects, will prolly add those to the front of mine when they need doing........
I like the look of the JKS ones as well
deer4011
Jan 12, 2021 07:10 AM
OffroadFrance
Jul 9, 2014 03:38 PM
JPSpen
Oct 12, 2012 03:15 PM
texci77
Mar 30, 2012 09:40 AM
collin Barrows
Off Topic
Jul 30, 2011 07:09 AM
