DTC 1193
Old Jan 6, 2009 | 12:06 AM
AK Rover's Avatar
Default DTC 1193
After installing my new plugs and wires I reset my check engine codes so I could see if any codes pop up again and which ones. Prior to doing that I had 1193, 1447, 0158 and at least one other I can't remember at the moment. After driving for a while my CEL came back on and since I had my code reader on the passenger seat I went ahead and plugged it in and read the codes, after I stopped of course. The only code that came back was P1193 - Oxygen Sensor Heater Circuit Open Downstream. Anyone know if there is a fix for this code other than replacing the O2 sensors?
Old Jan 6, 2009 | 10:13 AM
Default RE: DTC 1193
Other then possibily a connection problem, as far as I know, there is no fix other then new 02's.
How many miles on your truck?
Old Jan 6, 2009 | 11:05 AM
AK Rover's Avatar
112,000 on the truck. I just bought it in July and have no idea if the O2s have ever been changed although I am suspecting that they have not. I did check all the connections and everything is clean and tight.
Old Jan 6, 2009 | 11:54 AM
hazletbassist89's Avatar
I was getting that code a few weeks ago and plugs and wires solved it.
Old Jan 6, 2009 | 11:56 AM
AK Rover's Avatar
Just did Bosch Platinum +4s and Magnecor 8mm wires. They cleared the other codes but that one came back. Afraid I may have to break down and replace the O2s.
Old Jan 6, 2009 | 01:22 PM
If it turns out you need 02's, go to Rover Connection and check out their 02 information. Turns out there are 2 different sets of 02's depending on your vin, so don't buy te wrong ones.
Old Jan 6, 2009 | 04:01 PM
AK Rover's Avatar
Thanks for the help Mike. I'll probably be contacting you before I actually buy the O2 sensors to help make sure I get the right ones.
csp
Jul 1, 2013 07:33 AM
Maytag
Jul 21, 2012 05:00 PM
kayaku
Oct 5, 2008 09:26 PM
kayaku
Sep 27, 2008 02:02 PM
vjm530
Dec 22, 2007 11:30 AM
