Dual Battery Set upfront...
Here’s progress on mine, again, I haven’t actually had time to fit it all in the truck to check for final fit net, but the battery support sits nice the plastic tray. The thing I’m most concerned about is the height, I think my math works out but I’ll be insulating the crap pout of the positive terminal and closing the hood real gently until I’m sure.
GoRoll (10-20-2019)
No cutting of fender well.
my trunk load space was pretty valuable, so I wasn’t looking to run lines back and forth- the wire would have been a great expense unnecessarily.
Putting them side by side cured a lot of that. Plus, placing the selenoid close by relieved a lot of excess wire. I found ample space in the front corner & noticing pictures of others who’ve mounted there- I knew it could be done.
You’ll want to consider an external or auxiliary fuse panel. Blue Seas makes great waterproof panels in various sizes. Keep good labels, use good urethane coated stranded lines.
It took me a loooong time to slowly educate myself, lay out all the architecture to it at a pace where it wasn’t too costly & breaking the time to. Had a blast fabricating all it & well worth it.
The following 4 users liked this post by SundayFunday:
Nice - I thought the height of the battery was going to hit the hood so i opted out but I may just do it way. Like I said, Im not in a hurry so I gotta rethink the whole set up now...
EDIT - Do you have a photo of the bottom of the battery? Just curious how you made it flat - I have an idea in my head but I just want to see how your battery holder is set up.
This is the that I got - it's IP65 - not sure if i want to keep it under the hood...
I got a as well - If I decide to have it under the hood, I will probably get a better secured water proof one...
Also got the for the back...
Thanks for the clear answer - I dont want my trunk any heavier because I have an RTT more towards the back.
Since we are on this subject....
Can AGM > VSR > LITHIUM 100Ah be set up this way?
I'm wondering if anyone has done it and if its safe.
GoRoll (10-21-2019)
Lithium batteries are going to replace lead acid batteries, but common lithium batteries like used in Tesla are not suitable for 12V systems and raise safety concerns (thermal runaway). For that application LFP ( lithium iron phosphate or LiFePO) batteries are used, which have several advantages: longer cycle life, constant discharge voltage, nominal 3.2 V output = four cells can be placed in series for a nominal voltage of 12.8 V, good safety characteristics, thermal and chemical stability. Disadvantage is higher price and lower specific energy compared to other lithium batteries, but it is still 2 to 3 times better compared to lead acid batteries. It means you can get the same capacity at about one third to one half weight/volume compared to lead acid batteries.
100Ah LFP battery capacity should fit into the dead room behind the vent next to the cubby.
GoRoll (10-21-2019)
