dual steering dampers
What steering shocker do you think is the best?
I think I've got the LR original or a later replacement. Hit a pothole yesterday and a slight wobble on the steering, nothing too severe just a slight tremor. Maybe need to check out the steering joints etc.
I'm in the process of changing the shockers all round (probably Terrafirma if they ever answer my question about the overall length vs the original LR shockers), the rear air springs and will include the front road springs as these are original and 11 years + 121K miles on them.
When I changed the OEM for the Terrafirma last week, the latter was 2-3 times stiffer than the OEM (with 74K miles on it). I wonder how the Terrafirma compares to the Bilstien? Usually Bilstein shocks are as stiff as hell.
Edit : I'm talking about the steering damper, not main shocks.
Also have you tried replacing the panhard rod bushes? It seems to me that these are what locate the axle side to side, so are doing a very tough job - and if you are feeling some shudder this might be the culprit.
The panhard bush at the axle end is the only bush in my front suspension that feels a little suspect to me. I was thinking of changing it, but I'm not sure about OEM vs. poly.
I just recently changed nearly every single squishy on my truck (bushings/ball joints/panhard/track&drag/mounts/etc)
i just want more dampening. figure dual is easy way of doing it." rut yank "is a little harsh. trying to lessen it. plus since my tt was put in the front, I feel like acceleration is trying harder to straighten out my turns.....but I doubt damper will make a difference with that.
You say the Terrafirma steering shocker is 2-3 times stiffer than the OEM. Does that help or just put more strain on the steering gear linkages and PAS pump?
It seems I'm gonna be busy soon with all the upgrading of the front and rear suspension, steering equipment, engine and autobox mountings etc. In fact I may well replace all of these bushes front and rear: Land Rover Parts - FRONT PANHARD ROD - DISCOVERY 2 ............... I suppose it's the price for running the old truck for so long without doing all of these before. Done the brake pads and rotors a few times though.
I changed the steering damper because I was trying to fix a problem where the steering wheel would shudder when going over large bumps at highway speeds. It really did the trick, I am very happy with the steering now. Seemed like a well made product too, and not super-expensive at $55.
I think panhard bushes are next. Has anyone any input on OEM vs. poly, and then on the different grades of poly?
