Dummy o2 sensors
Old Feb 10, 2009 | 04:17 PM
tomfraser's Avatar
Default Dummy o2 sensors
My exhaust flanges separated from the pipe so I just went out and got 2 of them from the junkyard... I'm going to run straight pipe from those to my muffler, because the cats rattle, and i cannot afford new ones, and the only thing keeping me from doing this is my 2 o2 sensors (1995 3.9L engine, so I don't have o2 sensors after the cats)
I've read that you can purchase dummy o2 sensors that feed the ECU info so it thinks everything is fine, does anyone know were i can get these? Or what type of circuit is inside the o2 sensor so i can replicate it?
Thanks
Old Feb 10, 2009 | 04:40 PM
Default RE: Dummy o2 sensors
Cany you just use your old ones?
Even if you get dummy ones they still need to be installed.
I do not know where you can get dummy ones.
You could get universal ones for have way cheap. Probally cheaper than the dummy's.
Old Feb 10, 2009 | 04:52 PM
tomfraser's Avatar
the holes for o2 sensors will be gone... there is not enough pipe between the hole and and the cat to save them
Old Feb 10, 2009 | 05:07 PM
You will have to drill new O2 holes and tap threads or weld them in.
Old Feb 10, 2009 | 05:48 PM
tomfraser's Avatar
yeah... thats why i was hoping for dummy o2 sensors...
Old Feb 10, 2009 | 05:54 PM
SDinDS's Avatar
You mean like this??
http://www.o2simulator.com/index.php...cf7cc33703c2fa
Eric
Ithink that dummy o2's need to be installed too, they need to get hot to work, I might be wrong...but a muffler shop can install your o2's for cheap.
Old Feb 10, 2009 | 06:09 PM
tomfraser's Avatar
ORIGINAL: SDinDS
Eric
bingo!
thanks... I really appreciate it
Old Feb 10, 2009 | 06:17 PM
Those are not the kind I have seen.
The ones I have seen look just like a O2.
Old Feb 10, 2009 | 06:39 PM
AK Rover's Avatar
I am assuming that you live in an area where they do not do emission testing. I personally think dummy O2 sensors is a good way to cause real problems with your engine.
