DYI Discrete Winch Mount
Old Apr 12, 2016 | 11:18 PM
T-rex's Avatar
Got my winch yesterday and installed it today! It was a tight fit, but I'm very pleased on how it turned out!
I worried a little about the added weight so before the installation I put a measuring tape vertically by the bumper and set all the different items I'd be adding on the bumper - it only dropped about 1/4 an inch with the added weight.
Sweet!
First bracket installed.
I started with installing one bracket - then mounted the winch on the winch plate.
Superwinch 9.5 mounted on the cut down Badlands winch plate
I used a floor jack to lift the winch up into place - then mounted the other side bracket. I had to go this route - with both brackets in place the winch was too wide to fit between them!
from above with the front grill removed
I kept all the bolts lose - once everything was in in place and where it should be I tightened the bolts.
view from below
I have a TMJ steel bumper - it had a panel that you remove when you put a winch in - the only miss step was that it's a few inches off center! If I had of known this I would have cut the mount plate to match - it would have given me a few more inches clearance on the motor side of the winch - that side was really close to the side bracket. The fairlead is not exactly in the center of the opening - it's centered to the vehicle, just not the space in the bumper.
Finished! Love it!
There was plenty of wire to reach the battery - I left the control box in place on the winch instead of mounting it elsewhere. I decided to connect the controller permanently and leave it in the space by the jack. I've got the juice disconnected so no accidental activation! I think I'll look into a quick connect/disconnect gizmo so activating the system will be super easy (hope to never have to use it).
Old Apr 20, 2016 | 08:23 PM
T-rex's Avatar
Tested the winch set up today. Pulled some tree stumps out for my in laws. Worked like a charm and the winch mount cradle didn't move a bit!
Old Apr 21, 2016 | 10:02 AM
Eurobahn LandRover's Avatar
Former Sponsor
Great post, thanks for sharing! Glad it worked out so well for you.
Old May 9, 2019 | 04:56 PM
Xjsport95's Avatar
4wd High
Do you think it would work behind a stock bumper?
Old May 10, 2019 | 07:35 AM
SundayFunday's Avatar
Looks great
I’ve done that with a TJM on a previous disco of mine
and decided this time I didn’t want the bull bar up front at least for a while.
a ton of measuring - but I made it happen with a HF winch tray & some custom steel reinforcing.
Old May 10, 2019 | 07:37 AM
Old May 10, 2019 | 07:46 AM
jastutte's Avatar
Originally Posted by SundayFunday
that looks really clean!
love the white disco.
Old May 10, 2019 | 11:48 AM
mln01's Avatar
And here's a writeup from a few years ago by a guy in the U.K. who accomplished approximately the same thing. Elegant solutions.
www.discovery2.co.uk / T-Max Winch
Old May 10, 2019 | 12:20 PM
That write up was quite inspiring-
The thing is, his fair lead is below the middle of the bumper. In the mesh grille below.
I specifically wanted mine in the middle of the stock bumper.
Non the less- very nice To all doing discrete winch fabrication
Old May 14, 2019 | 11:01 AM
losinov's Avatar
A DIY post on how you fabricated your setup on the white disco would be priceless! Could you talk a bit more about the reinforcement you had to add to the HF winch tray and the bumper?
