EASY QUESTION :: Rims-- Range Rover (03-05) wheel conversion
Old Feb 13, 2013 | 05:56 PM
capthook's Avatar
Default EASY QUESTION :: Rims-- Range Rover (03-05) wheel conversion
Hey guys! Not my personal preference for my own dii because I like more rubber-- but my dad has two sets for his DII, and the summer set is chrome '03-'05 wheels. The lugs don't seem to go all the way into the wheel which seems pretty unsafe to me. Are there spacers we need or something?
If so, where can I pick em up? Thanks in advance !
Attached Thumbnails EASY QUESTION :: Rims-- Range Rover (03-05) wheel conversion-image.jpg
Old Feb 13, 2013 | 05:58 PM
ZGPhoto's Avatar
Well the lug nuts are different for L322s then DIIs.
Old Feb 13, 2013 | 07:09 PM
I believe that wheel is a hub centric wheel and would need a adapter.
Old Feb 13, 2013 | 07:49 PM
capthook's Avatar
Mike!!! Good to see you are still out there helping LR owners mate! I truly owe you a lot my friend. anywho -- who's got the adapter cheap!
Old Feb 13, 2013 | 07:59 PM
jafir's Avatar
D2 wheels are also hub centric, but the center bore is a different size.
google hubcentric ring. you'll want a set that goes from 70.1 hubs to the 72.6 center bore of the RR wheels. I think. I provide no warranty with the advice or numbers, etc. Good luck. You also need to use the RR lugs nuts.
Old Feb 14, 2013 | 10:03 PM
capthook's Avatar
Talking
Sounds good, thanks for the advice.. Is anyone sure of the exact sizing... And where to find both lugs and adapters cheap? My pops is ready to go to the stealership for his lugs... We want to go snowboarding up in flagstaff next weekend So any advice is truly appreciated !!!
Old Feb 15, 2013 | 06:31 AM
drowssap's Avatar
"where to find both lugs and adapters cheap?" your not going to find them cheap
Old Feb 15, 2013 | 07:11 AM
jafir's Avatar
Hub adapters are plastic. Probably less than $40. Just google them, and I bet the sites you find can confirm the sizes. The lugs will need to come from a rover parts place or dealership.
Old Feb 15, 2013 | 08:49 AM
ZGPhoto's Avatar
haha especially lug nuts, they're like $8 a piece, and you need at LEAST 20, should have 23 for the spare, nearing $200 JUST for lug nuts. $400 or so for adapters.
Old Feb 15, 2013 | 09:17 AM
jafir's Avatar
These aren't the same kind of adapter. No lug nuts required. They are just plastic inserts that change the size of the center bore. They are like $40.
