Eating Front Driveshafts
Old Jan 19, 2009 | 03:27 PM
mrcrptguy's Avatar
Default Eating Front Driveshafts
Any advice is appreciated on this. I have a 98 Disco that had a lift already Installedwhen I bought it. It looks like a 3 inch body and a 3 inch suspension. I had to have the front driveshaft completely rebuilt about 3 months after I bought the truck. Now 6 months later I hear the same squeeking and clanking as before, so it's parked and I'm getting ready to drop the driveshaft again and take it to the shop that rebuilt it the first time. I have heard of caster correcting bushings, will that help? I have'nt had the geometry checked but the driveshaft looks nearly straight.
Old Jan 19, 2009 | 03:52 PM
Disco2Guy's Avatar
Default RE: Eating Front Driveshafts
So you have a factory driveshaft running on 6" of lift? Have you looked at a Tom Wood's driveshaft?
Old Jan 19, 2009 | 04:41 PM
Yeah, its the lift. You need to figure something out for this or you will be rebuilding the D/S every 6 months.
Old Jan 19, 2009 | 04:55 PM
Disco Dave's Avatar
just a 3" suspension lift, right? the body lift should no effect on the driveshaft. i would say its a lift problem, maybe due to poor installation. any way to find out if it was a backyard job or done by a shop?
get the lift checked out and have all geometry checked!
Old Jan 19, 2009 | 06:41 PM
mrcrptguy's Avatar
Sorry guys, here's more info. It's a RoverTym suspension lift with the correct driveshaft with the (double cadon)in the rear. I was told by the previous owner that he had the body lift fabricated. I found a diagram online of a driveshaft with double joints at each end. any comments?? suggestions?? Thanks
Old Jan 19, 2009 | 06:58 PM
You need to look at a dual double cardon to handle that much lift.
Old Jan 19, 2009 | 07:01 PM
llesra's Avatar
youll need a double cardan in the front. since you have a double cardan in the rear, you'll have to check if the pinion angle was changed accordingly.
Night Train's Avatar
I've never used them but as mentioned earlier - I'd start by calling Tom Woods, 4xshaft.com - if mine was lifted I'd have these guys make me one.
Old Jan 19, 2009 | 07:09 PM
mrcrptguy's Avatar
Awesome guys, Thanks. I thought that I might need a dual double cardon but wasn't sure. Thanks for all the info.
Old Jan 20, 2009 | 12:11 PM
mrcrptguy's Avatar
OK, I took the driveshaft to the shop and they said there is nothing wrong with it. and it feels fine to me also with no play or hang-up spots. I drove the truck with the cdl locked, no front driveshaft and heard nothing, no squeks shimmys or clanks. Is there somthing else I'm missing? The front diff seems tight with very little play, the same goes for the transfercase. What really stumps me is that if it were the transfercase or the diff making the noise shouldn't it make some type of noise while driving locked-in even without the driveshaft?
