EBAY Cats and y pipe
Old Jan 14, 2022 | 08:13 PM
JohnZo's Avatar
State of Washington stopped all emissions checks over a year ago. Reason: automobile technology has advanced, and old cars are dying out. The 94 Disco (no downstream O2 sensors) I bought with Missouri plates had small patches welded on the cats where the innards had been removed (as I later discovered). That can cause some reverberation in the cabin, so straight pipe is better. Personally, I prefer having cats in good working order.
Old Jan 16, 2022 | 10:49 AM
Tomzsix's Avatar
What MM six points do you use for exhaust nuts?? I've already ordered the ones from Amazon and sprayed PB blaster all over/
Old Jan 16, 2022 | 05:36 PM
ahab's Avatar
You mean wrench size? I'm pretty sure it's a 13mm deep socket. Could be a 14mm. The outlet flange will be the same.. You'll need some extensions, and possibly a swivel.
Old Jan 16, 2022 | 07:01 PM
Dave03S's Avatar
I found some of the downpipe bolts were easier to get at from beneath, long extensions required.
Old Jan 17, 2022 | 11:36 AM
JohnZo's Avatar
Default SAE vs Metric fasteners
I have found many of the motor fasteners are actually inch sizes rather than metric. Not sure about the nuts for the y-pipe connections, but 1/2 inch might fit a bit snugger than 13 mm.
Old Jan 18, 2022 | 02:42 PM
Harvlr's Avatar
Engine hardware is SAE because it’s 1960’s Buick. I think everything outside of the engine is metric.
TyTyBinks
May 8, 2021 03:06 PM
ocarlo
Sep 25, 2020 02:44 AM
Jeff Blake
Jun 26, 2017 01:52 PM
DiscoIIBrandon
Feb 8, 2011 07:44 PM
dieselgeek
Feb 3, 2009 12:25 PM
