EBC brakes giving me issues?
Hi all,
So I installed new EBC pads and rotors on all four corners of my 2003 DII about 8,000 miles ago. Green Stuff pads and the dimpled and slotted rotors. At first, everything was just fine - better braking, smooth stopping, etc.
Now, I have a nasty vibration when I brake. It seems to me that the rotors have experienced "run-out", which EBC profiles in a bunch of places on their website talking about how it is not an issue with their rotors or pads. Heck, you can even check out this link (http://www.ebcbrakes.com/automotive/pro_cut_lathe.shtml) about the "Pro-Cut" lathe and how they recommend getting the rotors skimmed while on your vehicle (even a brand new installation.)
I've installed rotors and pads on a number of vehicles and have never experienced this kind of issue within 8,000 miles.
So, my plan is to have the rotors re-surfaced and install new pads. My big question though....how do I keep it from happening again? Anyone else have this issue?
Thanks.
Thanks.
on
You may want to look into this with a couple of shops. I have always been told that the slots and holes will tear up the lather bit and the rotors.
Of course you want to get them measured first and see if they are in fact warped. I run DBA rotors, nearly 100,000 miles on them and they have never warper after a lot of hard driving.
So, if this is a common issue, what is the fix?
Willie - no towing, no heavy loads, no heavy braking. Just basic around town kind of use. I haven't even been off-roading since I installed these. My stock rotors that I removed didn't have any warping issues either, they were just worn. I was hoping these EBC brakes would be an upgrade, but this is driving me nuts!
