Ecu location
I've replaced the maf sensor, Purge valve, and o2 sensors and the codes are still coming up after I clear them. Also, there is a code for the cam sensor that won't go away. My d2 is running perfect and I still have all these codes. Don't know what else it could be? I pulled the engine about 9 months ago and replaced the short block but I accidentally smashed 6 wires behind the ac compressor and ran it unknowingly. Those are fixed the right way with heat shrink and the same codes are still coming up from when the wiring was bad.
The ECU is behind the glove box, bolted to the side of the body, covered by the kick panel. You cannot replace just the ECU, unless you know someone that can sync it with your BCU afterwards... my hawkeye scanner will NOT do this with the currently software.
Read the last post on my thread for my 99 project car for more details, I just replaced my ECM and BCU about an hour ago.
https://landroverforums.com/forum/di...1999-d2-40222/
