ECU replacement.
Old Apr 16, 2016 | 07:53 PM
johnbbensonjr's Avatar
Default ECU replacement.
Ok so here is what I have. ECU has gone bad or so I was told,engine light was blinking and The truck has little to no power at acceleration. I have taken the ECU out, I was told that I can buy a use one with the cluster and link it to my truck. What is the proper way of doing it ?
Old Apr 16, 2016 | 08:34 PM
cappedup's Avatar
Engine light blinking and low power does not equal bad ECU. What other evidence do you have?
I would reverse your actions a little bit. Put the ECU back in and try and diagnose things more.
Did you have some codes read, that came with the blinking engine light? That's the start of diagnosis.
Old Apr 16, 2016 | 09:16 PM
The_OGCJR's Avatar
Yes please post all the codes
Old Apr 17, 2016 | 01:11 AM
Ok,will do as soon as day break.
Old Apr 17, 2016 | 04:54 PM
OffroadFrance's Avatar
X1 .................. also an ECU switchover isn't that simple as they need to be matched.
Old Apr 18, 2016 | 02:58 PM
Ok I have 6 codes.
P0305
P1319
P0307
P0304
P1300
P1884
Old Apr 18, 2016 | 03:12 PM
shanechevelle's Avatar
P0305 - Misfire on cyl 5
P1319 - Misfire detected with low fuel level
P0307 - Misfire on cyl 7
P0304 - Misfire on cyl 4
P1300 - Random/multiple cylinder misfire detected Catalyst damaging level of misfire on more than one cylinder.
P1884 - Cant find this one.
Old Apr 18, 2016 | 03:24 PM
So what steps are need to fix this problem.
Old Apr 18, 2016 | 07:58 PM
cappedup's Avatar
Good work getting that done. First steps.
Have you done any work on the plugs, wires or coils at all recently?
Yes. Go back and check all your work. Something could be amiss with what you've done. Pay very particular attention to the wiring order from plugs to coils.
No. Check out those things. Pull the plugs from the misfiring cylinders to check them out. Watch the truck running in the dark, see if you see arcing sparks where they shouldn't be.
How old are the wires?
Slightly advanced move. Reset the codes. Then swap a wire from a known not misfiring cylinder with one that is. Run the truck, compare the codes, see if the fault moves.
Don't drive your truck in this state. You will destroy the cats = $$$$s.
Old Mar 31, 2019 | 11:54 PM
DavidOHendo's Avatar
Banned
Ok I have 6 codes.
P0305
P1319
P0307
P0304
P1300
P1884
I have a bad ECU or BCU and am getting 0307 too. Also 1535 and 1887.
