ECU stopped communicating with ScanGauge
Old May 24, 2016 | 03:41 PM
  #21
number9's Avatar
tie the 8 pink wires together with a big honking wire nut or solder?
Bridge or plug contacts may need additional cleaning. Repair or temp repair of cap's bridge possible? Check at ECU yet?
Old May 24, 2016 | 04:05 PM
  #22
NickAdams's Avatar
I pinned out the back (wire side) of C0286 and have continuity between all pink wires. I used my Fluke 78 diode checker, which I believe only beeps at or near zero ohms resistance.
As far as checking at ECU: today I have done further cleaning of connectors after checking Rave and learning connector 4 of ECU "facilitates use of TestBook."
Old May 24, 2016 | 04:18 PM
  #23
NickAdams's Avatar
LO AND BEHOLD! After a rigorous cleaning of all connectors at ECU, everything came back to life! The honest truth: an entire can of CRC electrical cleaner (the good stuff, plastic safe) yielded one little green fleck one-half the size of a grain of sand. But after letting it dry and putting it all back together, the scangauge works just like new!
Old May 24, 2016 | 05:11 PM
  #24
number9's Avatar
Glad to hear about your good t/s.
Old May 24, 2016 | 07:24 PM
  #25
Charlie_V's Avatar
Congrats!
Old May 25, 2016 | 02:40 PM
  #26
NickAdams's Avatar
Of course, blower motor quit on drive home. And, of course, I broke two wires, which were badly corroded, on headers C0286 and C0287. The headers were still hanging down in the way of blower motor removal. Wiring repair made.
Motor removed, cleaned and tested on truck before final assembly. Did not work after bolting into truck. 12 volts at connector, so new motor on the way.
Old May 25, 2016 | 03:07 PM
  #27
Charlie_V's Avatar
Condolences.
Never ends. Same here.
Old May 25, 2016 | 03:20 PM
  #28
DiscoBuckeye's Avatar
The $$$ you are saving by doing it yourself? I'm a glass half full guy and I would guess most here are too.
tsuyoi
Sep 22, 2020 10:37 AM
Disco_Fever
Feb 17, 2011 07:01 PM
joatman
Jan 20, 2011 01:33 PM
mikefa
Jun 15, 2010 08:02 PM
mcrw
Oct 14, 2008 04:28 PM
