Electric AC Consenser Fan
So, I just replaced the electric fan with a used unit. The old original fan seized up (literally started burning up while driving down the road). The used fan was bench tested by me prior to installing, it ran perfectly. The fan swap was plug and play. Unplug old, plug in new. Well, not that easy for anyone who needs to tackle the job. Had to pull the grill, headlights, etc...
Now, the fan is not switching on! Should the fan come on as soon as the AC is switched on (with compressor running)? My ultra gauge temps hit over 208 yesterday at idle 90 degree ambient (never seen that before; 180 stat coolant levels on the money) w/ AC on and electric fan never kicked in. My original fan seemed to run as soon as AC switched on. What gives?
Do you think the old fan took out the Fuse or relay? Away from the truck for the weekend will check them later but wanted to get a feeler of items to inspect.
Old fan motor would have taken the fuse with it when it siezed.
Spec page says on at 212F, off at 202F; or
When AC on, AND slower than 50 mph and AND ambient temp above 82F it should be on, above 62.5 mph or below 77F outside temp it should switch off. Might not need to wait until high head pressure is reached in all conditions.
So you could be driving 65 mph, 206F on Ultra gauge, AC on, and the fan should be off.
Have the truck running w/ the AC on. Touch the metal circular disc on the electric fan (be careful it may be really hot). If it is real hot it is seized.
twilightcall
03-04-2018 06:55 PM
