Electric fan
Old Aug 6, 2008 | 09:42 PM
apcollin's Avatar
Default Electric fan
is it worth replacing the pully-powered fan (Disco 1) with an electric unit? i thought the removal of the drag may increase usable power/improve efficiency.
Old Aug 6, 2008 | 09:46 PM
Default RE: Electric fan
Do you off road? If so then no, you will overheat. The electric fans dont pull enough air.
Old Aug 6, 2008 | 09:54 PM
sailorcolin's Avatar
is it better to replace the pulley powered fan with a aftermarket pulley powered fan?
Old Aug 6, 2008 | 09:57 PM
No, just replace your viscous clutch when it goes bad. You should be able to spin the fan freely by hand.
Old Aug 6, 2008 | 09:59 PM
ok thanks because i was thinking of doing that but wasn't sure about the electric switch or not.
Old Aug 6, 2008 | 10:01 PM
There is no electric switch on a viscous fan clutch, it is controlled by a bi-metalic spring. When it gets hot it locks the clutch. The clutch is filled with liquid.
Old Aug 6, 2008 | 10:07 PM
no sorry what i ment is that i was thinking of switching to a electric fan but didn't know if i wanted to and then i wanted to replace the stock fan but didn't know if it would be any better.
Old Aug 6, 2008 | 10:13 PM
Ok, I think we are on the same page now.
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
vonfonk
May 6, 2006 06:50 PM
mikemeyer0
Mar 30, 2005 03:12 PM
