Electric fan
Old Aug 18, 2010 | 10:14 PM
David A's Avatar
Default Electric fan
As I started up my 03 today to take it to the shop to get the oil pump replaced the electric fan came on with a bone cold engine and the idle was still up...shut off in about 60 to 90 sec...Thoughts?
Old Aug 18, 2010 | 10:36 PM
bosshogt's Avatar
Default Are you refering to the A/C condensor fan?
The A/c condenser fan will only come on when the air conditioning is turned on. That is the only electric fan our you DII's. I just replaced mine after noticing that it was not working. You can see it turn by looking into your grill when when your A/C is turned on. It keeps your coolant and engine cooler by up to 10 degrees in the hot summer. I tracked this by monitoring my ScanGuageII temp in the summer when my fan was broken & then after I fixed it. My 03 runs 188 - 205F most the time. Mostly sits at 195 on the highway. Thats with 2 bottles of water wetter while my fan was comming in the mail.
Old Aug 19, 2010 | 08:51 AM
David A's Avatar
Thats the one....But its coming on without the a/c on every morning on a cold start.
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
vonfonk
May 6, 2006 06:50 PM
mikemeyer0
Mar 30, 2005 03:12 PM
