Electric fan replacment
Old Mar 16, 2012 | 01:23 PM
94svt50's Avatar
Default Electric fan replacment
After installing my new ultra guage I realized my electric fan was never kicking on at 212deg. and got as high as 215deg. in traffic. Upon further inspection I found the fan unable to be spun by hand and the 40 amp fuse that operates it was also blown. I assume the fan is shot so I checked with AB and found the replacment is $375! Thats a bit steep, any one used a generic after market fan as a replacement? Autozone has a number of inexpensive electric fans and didnt know if one of these could be modified.
Thanks
Old Mar 16, 2012 | 01:29 PM
mj_duell's Avatar
Thanks
I went through that exact same thing when I purchased my Disco. I replaced it with a 12" Hayden unit for $55.00 at the local PepBoys. Works great and was easy to wire. You will have to fabricate brackets for it like I did using the stock mounts. Take your old fan down and try and get the closest version as far as cfm, size etc.
--Mike
Old Mar 16, 2012 | 02:29 PM
94svt50's Avatar
Thanks! I hoped there was an alternative to oem.
Old Mar 16, 2012 | 03:07 PM
mj_duell's Avatar
I will get some pics for you if I can seeing I am working on the Disco this weekend. One word of caution, make sure you test the fan direction when you hook it up. Use a piece of paper or something to make sure its pushing air in the correct direction. The Hayden fans are reversible.
--Mike
Old Mar 16, 2012 | 05:29 PM
94svt50's Avatar
Would something like this work?
Buy Mr. Gasket Electric Cooling Fan, 12", Thickness 3.09 in. 1986 at Advance Auto Parts
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
94svt50
May 10, 2012 09:15 PM
cpl55
Apr 20, 2007 01:06 PM
