Electric Fan worky/noworky??
Old Sep 29, 2009 | 02:11 AM
Urban Panzer's Avatar
Originally Posted by Spike555
See, on a DI you turn the a/c on and the fan comes on, turn the a/c off and the fan shuts off, simple.
Man I love DI's.
Yes your right, simple really, but does have its negative sides,
1. the load is always on the alternator when it does not "really" need to be.....
2. If your out on the trails and you have the aircon on, you have to remember to turn it off when wading as the fan throws even more ****e into the engine bay, atleast with a D2 setup, you only need to worry if its 28°c or more, not a big issue I know (but I have to fight the D2 corner!!)
Old Sep 29, 2009 | 10:25 PM
Night Train's Avatar
I got your back!
Old Sep 30, 2009 | 07:12 AM
jayv's Avatar
Just an FYI: for DIIs
for a/c,
1. electric fan will come on if driving less than 50MPH, AND ambient air temp is 82 degrees or more.
1a. fan will turn off if speed reaches 62.5 MPH or greater OR ambient air Temp decreases 77 degrees or less.
for engine cooling:
2. Fan will come on when coolant reaches 212 degrees and off when coolant temp is 202 degrees or less.
for engine cooling after igition is turned off:
4. fan will come within 10 seconds of turning truck off if air intake is 140 degrees or greater AND coolant temp is 230 degrees or more
4a. fan wil turn off after 10 minutes OR coolant reduces to 212 degrees or less.
this is taken directly from RAVE. sticky maybe? ive seen this come a lot.
Old Oct 1, 2009 | 10:50 AM
KWKING's Avatar
7th Gear
Default A related issue
I also have a 2001 D2 with an A/C blower that seems to have a mind of it's own. As best I can tell there must be a relay or connection adjacent the glove box for the blower motor. The blower will shut off if the box is closed too hard and won't fire back up until it decides to or when I hit under the dash in the "right" spot. It also has crapped out when I have hit a good size bump or pothole as well, but there is no discernable pattern on when it stops or starts.
Thanks in advance for any guidance!
Old Oct 1, 2009 | 01:54 PM
I'd say you have a short, the least you could do is trace all the wiring associated with the blower - to make sure the connections are tight, sounds like it could be a connection that is wiggling loose - don't look check - push together check
Old Oct 26, 2009 | 11:50 AM
KWKING's Avatar
7th Gear
Default Additional Information
Thanks for the previous advice, but still on & off at will. Here are the things I have done.
1) Checked (unplugged & reseated) conections.
2) Checked blower motor by applying 12V and it works like a charm.
3) Voltage coming into blower reads 4V.
4) Checked all fuses as well.
Now the interesting part.........I have noticed that the audio system on the right side cuts out when the blower cuts out.
Is there a common ground connection for those two systems that would explain things?
Thanks
Old Oct 26, 2009 | 03:24 PM
Don't wait, start your truck up, let it idle with the a/c on, if the fan doesn't come on at operating temp. it is most likely bad. Better to find it sooner then after you toast your engine.
Old Oct 27, 2009 | 12:58 PM
Mike it hasnt been over 70 degrees here since i posted this thread, according to the responses i has to be above 77 to even come on
Thanks
Robert
Old Oct 27, 2009 | 02:39 PM
Your fan will come on for 2 reasons, the a/c has reached max head pressure and or the engine has reached operating temp and you are doing stop and go driving.
Mine was on today while driving around in Denver and it's going to snow tonight, so it is not warm out.
Old Nov 18, 2009 | 05:52 PM
Finally - after some time and a move - I found out my fan DOES work,
thanks to all that responded - there is some good information here
