electric fan - which years?
Old May 4, 2010 | 09:05 AM
NiteTrain's Avatar
Default electric fan - which years?
what year DIIs have electric fans for cooling the radiator? Do they have mechanical fans and electric or just electric?
Old May 4, 2010 | 02:32 PM
NiteTrain's Avatar
anybody have an electric fan on their '00-'04 DII?
Old May 4, 2010 | 03:15 PM
They all have a mechanical and one electric fan. D1's had 2 electric fans and one mechanical.
Why do you ask?
Old May 4, 2010 | 03:40 PM
NiteTrain's Avatar
ahh ok. I thought newer models might have an electric main fan and auxiliary. While I'm doing this water pump swap I was toying with the idea of replacing the mechanical fan with a large electric. I read where some people use a fan out of a ford taurus (common swap for Jeeps) in their discos.
Old May 4, 2010 | 04:27 PM
03discoman's Avatar
if you do this... let me know how... i hate the big power robbing mech fan
Old May 4, 2010 | 05:47 PM
I have heard of a few people doing this but you first need to make sure you get at least the same volumn of air at all engine temp ranges.
Old May 4, 2010 | 06:50 PM
You will be fine with a all electric fan set up as long as you dont off road, once you start off roading in the summer the electric fan will not move enough air and you will overheat.
Old May 4, 2010 | 07:44 PM
NiteTrain's Avatar
spike, electric fans are much better off-road than mechanical..they pull more air and use less horsepower to operate. They are a must have on the trail during the summers here in the southeast.
Old May 4, 2010 | 08:25 PM
I have heard the opposite.
Because they only run at one speed they always pull "X" amount of air no matter what.
Where as a clutch fan pulls more air the faster the engine turns.
I am only going buy my experience from people I have talked to so I admit that my info may not be 100% correct.
Old May 4, 2010 | 08:57 PM
greg409's Avatar
I've run twin 12" electrics for a year, one on stat (160), one on switch (dtdp, center off)
that let's me shut them both off, if necessary.
I was using the popular 16" 2speed lincoln (5600 cfm), before that, but it drew 39 amps on high speed.
Mine hasn't overheated since I removed the mechanical, including 5mph rush hour chicago, 90deg.
The twins draw 8amps ea, from summit, about $75, on sale.
(no shroud, close to rad)
I think the waterpump thanks me, too.(it lost about 5lbs. rotating)
luck,greg
