Elusive CDL Decal
Old Jun 1, 2017 | 11:01 PM
MacRoadie's Avatar
Originally Posted by mln01
I don't understand why you wouldn't just buy the one from Rovers North.
DECAL CENTER DIFF LOCK INSTRUCTIONS DEF, BAC501310, RNQ190 - Rovers North - Classic Land Rover Parts
I got the one pictured below from Rovers North a few years ago when I installed the '04 T-case shifter in my '99. It was listed for the Defender and is flat instead of the domed plastic but I didn't care. Unfortunately I can no longer find it in the RN catalog.
I did order that one, but since it is off a Defender, and the Disco version is sized to fit on a raised portion of the console molding, I wasn't going to assume the Defender decal was the same size (the consoles aren't even remotely similar so why would they have the same little raised surface for a decal?).
For $6.00 it's no big deal and I'll find out if it fits when it arrives, but I also figured I'd look around to find the actual correct decal if one was available.
Old Sep 6, 2017 | 12:04 PM
Jeff Blake's Avatar
What did you end up going with? Source?
Old Sep 6, 2017 | 05:23 PM
acg's Avatar
acg
I used this source when I converted my Disco to CDL a few years ago:
Discovery Transfer Case Differential Decal Sticker
Old Sep 6, 2017 | 07:06 PM
Jeff Blake's Avatar
Hmm that's not a CDL sticker
Old Sep 6, 2017 | 08:59 PM
mollusc's Avatar
The CDL part is the bit at the right on the black background, which says to consult the manual.
Old Sep 6, 2017 | 09:38 PM
Friday Night Disco's Avatar
The britpart from lrdirect comes with the right sticker
Old Sep 6, 2017 | 09:54 PM
Jeff Blake's Avatar
Unfortunately the britpart kit is not directly compatible with an 04 transfer case. I'm pretty sure I could get it to work... but I'm going to hold out a little longer for an 04 shifter
Old Sep 7, 2017 | 07:29 AM
MacRoadie's Avatar
I found a guy in Poland who was making identical copies of the original decals. I don't think he has them anymore.
Old Sep 7, 2017 | 08:40 AM
Paul Grant's Avatar
I have this off a DI with CDL. It has a little white scuff in the center.
Old Sep 7, 2017 | 09:57 AM
Jeff Blake's Avatar
That looks cool. I'll take it. Add it to my order
