Emergency brake excessive heat and dinging at me
All I recently had my 2004 Discovery impounded ….Long story
After I picked up the car it was apparent that the tow lot had their way with my car. Here is what I know they drove it 2k miles in 11 days and they removed the battery and installed a dead one. And I have a broken tail light lens. I noticed that on the – negative terminal has a tab that looks like it was attached behind the jack storage was disconnected. I was able to jump-start the car and get it home with this tab unconnected. I noticed a burning smell in the car on the way back and when putting the car back in the garage pulled the E-brake and I actually got a blister from the push button and the smell was coming from melting plastic on the E-brake. Also every time I put my foot on the break there is some alert that dings. If the radio is on it shuts off dings at me than comes back on till I press the brakes again. The car has no CEL or lights on that I can see
Any ideas?
Any ideas?
X2, Bad ground, possibly near the e-brake handle under the console. Spike posted some pics of what can happen in this situation. It can start a fire. Find that before you drive anymore. Sounds like if you can prove the damages you could take that impound lot to the cleaners. 2000 miles on it while it was impounded? What the hell! That is criminal.
Thanks for the input. I haven't touched it since getting it home. going to try the new battery and reground the terminal. I have to document everything wrong first
So here is the good.... a Circle K provided me video of the truck 900 miles away from the impound lot and its the staff I paid to get the truck back. Building up a super strong case for my law firm
reply for overheating E brake cable.
I had a similar problem with my 2002 discovery. Shorty after I bought it, the E-brake cable got red hot and actually burned right through it. The cause was the main ground had come disconnected. About your impound lot experience, I'd contact your state's attorney general's consumer affairs office. Good luck.............
Hey guys quick question. I had the same issue happen with me driving home, and I thought she was going to burst into flames. Luckily I was close to home. I am a new rover owner, and I was hoping someone could point me in the right direction as far as troubleshooting the grounding issue. More specifically, where the main ground is located. Thanks so much!
