EMERGENCY!! Dealer says my truck is toast!
Old Jun 20, 2011 | 06:31 PM
Camdisco24's Avatar
I bought my truck at 16, so I'm on the same page with you here. I can only do the basics on my truck, but in 4 years I have learned a lot. That being said, I personally would never take on head gaskets because that's a job I want done 100% right. I wouldn't trust myself to do that... But if you're adventurous, go for it!
Also, I'm assuming you went to Land Rover Columbia... They are connected with my local dealer here in Asheville and one other in SC; that whole trio of of dealerships is sketchy and notorious for ripping people off. I was quoted over $2000 to fix a Crank position censor and replace couple of belts. Thanks GOD I found my indy mech who did the whole job for $300. He was almost as pissed as me that they were going charge that much. Knew nothing about cars at the time, so they tried to take me for a ride.
Anyways, check out these two shops near you to get a second opinion:
German Autowerks
1821 Augusta Rd, West Columbia, SC • 803-794-7344
Yes its German, but many times these guys can handle the British engineering so it worth calling to check.
Philips Auto Tech
3137 Two Notch Rd, Columbia, SC • 803-786-1135
Again, not LR specific but it says they have expanded their services to LR. Worth a call as well.
Might be a really small LR shop in Columbia (usually there is near dealers...) so maybe someone closer will chime in.
Old Jun 20, 2011 | 06:55 PM
Old Jun 20, 2011 | 08:38 PM
ajmille's Avatar
Default Abs repair kit
ABS Modulator Shuttle Valve Repair Kit
Share
Qty
Our Price: $64.95
Item: SWO500030
In Stock: Yes!
Fits:
Discovery Series II | '99 - '04
Old Jun 20, 2011 | 08:39 PM
ajmille's Avatar
Qty
Our Price: $299.95
Item: 9542
In Stock: Yes!
Fits:
Rather than list out all the components of the brake kit yourself, we've done the work for you! Simply order the brake kit and get everything you need to do the job right the first time - without time-consuming re-ordering of forgotten parts! All of our Standard brake kit components are imported from the U.K. - guaranteed high-quality at a great price. Save yourself time and worry and order your brakes by the kit.
Kit includes the following components: #Product IDDescriptionQty. RequiredQty. In StockCost 1 ANR4582
Brake Rotor Front2Yes! $139.90 2 NTC8781
Brake Rotor Rear2Yes! $99.90 3 SF108201L
Screw Brake Rotor Locator 4.0/4.64Yes! $3.80 4 STC3684L
Lockheed Brake Pads - Rear1Yes! $34.95 5 STC3685L
Lockheed Brake Pads - Front1Yes! $47.95Total Value:$326.50Your Cost:$299.95You Save:$26.55
Old Jun 20, 2011 | 08:40 PM
ajmille's Avatar
Caliper Service Kit - Rear
Share
Qty
Our Price: $15.95
Item: STC1909
In Stock: Yes!
Fits:
Range Rover 4.0 (P38) | '95 - '02
Range Rover 4.6 (P38) | '95 - '02
Need it fast?
We operate East and West coast warehouses and offer ground, two-day, three-day and overnight shipping to ensure you get your order when you need it and at a reasonable cost.
Note: In stock orders typically ship same day when received Monday - Friday before 12:00pm Eastern.
ajmille's Avatar
Qty
Our Price: $29.95
Item: STC1919
In Stock: Yes!
Fits:
Discovery Series II | '99 - '02 | to 2A999999
Old Jun 20, 2011 | 08:42 PM
ajmille's Avatar
Head Gasket Set Composite V8 BOSCH Motors
Share
Qty
Our Price: $169.95
Item: STC4082BK
In Stock: Yes!
Fits:
Range Rover 4.0 (P38) | '99 - '02 | From VIN # XA410482 On
Range Rover 4.6 (P38) | '99 - '02 | From VIN # XA410482 On
NOTE: New headbolts REQUIRED when installing this gasket set. See Head Bolt Kit to right.
This new round of gaskets is specially treated with a composite coating to put an end to leaky seals once and for all.
Kit includes the following components: #Product IDDescriptionQty. RequiredQty. In StockCost 1 ERR6434G
Heater Pipe At Intake "O" Ring (BOSCH)1Yes! $1.49 2 ERR6621
Gasket Upper-Lower Intk Man 4.0/4.61Yes! $39.95 3 ERR6622
Gasket Intake Manifold ELBOW4.0/4.62Yes! $5.90 4 ERR6623
Gasket Throttle Body Heater1Yes! $2.95 5 ERR7202G
Coolant Elbow At Intake "O" Ring (BOSCH)1Yes! $0.95 6 MGM000010K
Throttle Body Heater Plate Kit1Yes! $21.95 7 STC4082E Head Gasket Set Composite V81Yes! $119.95Total Value:$193.14Your Cost:$169.95You Save:$23.19
Old Jun 20, 2011 | 08:43 PM
ajmille's Avatar
Engine > Cooling/heating
Water Pump
Share
Qty
Our Price: $109.95
Item: STC4378A
In Stock: Yes!
Fits:
Discovery I | '94 - '99
Range Rover Classic | '95 | For Vehicles with Serpentine Belt
Defender 90 | '97
Old Jun 20, 2011 | 08:44 PM
ajmille's Avatar
Qty
Our Price: $134.95
Item: 9291D2
In Stock: Yes!
Fits:
Old Jun 20, 2011 | 08:46 PM
ajmille's Avatar
If you keep the Land Rover and work on her and take your time you will know your truck inside out, these are some of the parts you will need, this is the best web site to get parts.If you sell your tyruck you will take a huge loss, put on your big boy pants and keep your cool we have all been where you are in one way or another.Good luck!
