Emission woes...
Old Sep 3, 2013 | 09:35 PM
  #21
jfall's Avatar
What kind of new O2 sensors did you put in?
If they are NTP or some such - then you put in Junk.
Or come goofy crap from Autozone.
Only Bosch will really work correctly.
Old Sep 3, 2013 | 09:42 PM
  #22
Canolime's Avatar
I used bosch direct fit from the start.
Old Sep 4, 2013 | 01:32 PM
  #23
jfall's Avatar
OK good news about the Bosch direct fit.
Now, if you put on a scanner - live data -
go to the O2 sensor monitoring mode.
Do the O2 sensors oscillate up and down from .998 down to say .02 volts?
This should happen a few times a second.
This is a feed back loop - when this is happening you are in closed loop which is where you want to be.
Old Sep 8, 2013 | 06:19 PM
  #24
Canolime's Avatar
Time for an update.
The good news is that as soon as I repaired the bad connection that I mentioned earlier in the thread all 8 of the codes that I had went away and have not come back.
As of now I have 2 brand new upstream o2s fitted and perfect cycling on bank 2. Bank one is only moving between 0.6-0.7 volts and s.t.f. Trim does not go below -24%.
My options as I see them right now are:
Rewire harness between bank 1 and ecm
Possible bad computer?
Possible stuck injector(s)?
I should mention that all my testing has been done in the driveway as I am unable to drive the vehicle yet and that the gas tank has 83 octane fuel in it which will be fixed as soon as I finish fixing the crash damage and get back on the road.
Any thoughts or comments would be gratefully recieved.
Old Feb 9, 2014 | 02:39 PM
  #25
completelymobile's Avatar
Please update when you have a chance ... interested in the final outcome and if low octane/bad gas was part of the problem?
'BamaBoy
Sep 15, 2023 02:29 AM
Yoops Racing
Nov 30, 2014 10:40 AM
bluerover95
Aug 10, 2010 09:17 AM
Dell
May 1, 2009 08:09 PM
savatage
Feb 12, 2007 07:25 PM
