Engine Code - P0447 - Rodent Damage?
Old Feb 10, 2008 | 01:07 PM
ccvalentino's Avatar
Default Engine Code - P0447 - Rodent Damage?
All,
A few weeks ago I posted a message regarding an engine code P0447 which related to an emission control valve. While working on the horn (which is non-functional by the way) I noticed what appears to be a chewed through wire on one of the sensors. A little closer look revealed a chewed hose also. Forgive the focus on the attached picture, but does anyone know what this is? It appears to connect to the fuel filler system. Given the code and what it means I can only assume that they are related. There is also what appears to be a cable that runs to the throttle body.
I can fix the hose and electrical connection myself, just need to know what it is so I can order the proper parts. This is a 2000 Discovery II.
Thanks,
Chris
[IMG]local://upfiles/9065/4CBA6CF4DC9847C7AFE11EC53553CDB5.jpg[/IMG]
[IMG]local://upfiles/9065/26E298DF040C40779F0C5B06427D9CFC.jpg[/IMG]
Old Feb 10, 2008 | 02:04 PM
Default RE: Engine Code - P0447 - Rodent Damage?
Update...Quick solder joint seems to have done the job.
Chris
pvangura
Jun 16, 2021 08:44 PM
sayeedA
Nov 15, 2011 11:02 PM
tunernewb92
Nov 19, 2009 10:36 PM
s4lex
Feb 11, 2007 02:40 PM
asmcmillin
May 7, 2005 11:19 PM
