Engine cooling Fan clutch
Old Mar 14, 2007 | 12:03 AM
igriego's Avatar
Default Engine cooling Fan clutch
Has anybody had any experiences changing out mechanical cooling fan clutch. Mine is sticking and now
I am getting loud fan noise as it is running all the time. 2001 D2 100k . Thanks in advance for any
advice it looks very straight foward just seeing if anything I should watch out for.
Irwin
Alb, NM
Old Mar 14, 2007 | 11:40 AM
Default RE: Engine cooling Fan clutch
Easy to take off if you have the narrow wrench needed to fit in behind the clutch hub.
Atlanti British sell them, you may also find them at a good tool shop.
While you are doing this, also look at your belt tensioner and the idler pulley, they may both need to be replaced if they haven't been done yet.
Mike
Old Mar 14, 2007 | 12:44 PM
igriego's Avatar
Mike,
As always, thanks for the fast reply and your experience is truly apprieciated.
Irwin
Old Mar 14, 2007 | 01:53 PM
98roverguy's Avatar
Check your water pump for play too. No fun when that thing goes out, disasterous - trust me....
jafir
Feb 10, 2017 11:08 AM
Merlin390
Sep 10, 2014 09:55 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
