engine hesitates on exceleration
RE: engine hesitates on exceleration
It's a '97 disco with the V8. Has 85000 miles. Did put a new MAF and changed the K&N air filter around 5000 miles ago. The codes where different then they where P1172 and P1179. I did change the MAF then, but only after your good advice of removing the K&N did the check engine light stay out. I kept the old MAF on the shelf. Just like any farmer like myself would. Do you think the original might still be good? No harm in trying is there! I must admit You guys sure do know these machines. I thank you for all the info you give.
