Engine ID?
Old Nov 12, 2021 | 10:08 PM
RA021226's Avatar
Guest
Default Engine ID?
After a couple of years of repeat codes and new parts not matching, I'm beginning to wonder if my salvage-titled D2 has an other-than-D2 engine. Where can I find the engine code on the block? And what code should I see if it is, in fact, a D2 engine? Thanks, mike
Old Nov 12, 2021 | 11:46 PM
Dave03S's Avatar
The code is etched in the block right where the oil dip stick goes in. You can look up the serial numbers and tell what model and year it was for.
Old Nov 12, 2021 | 11:49 PM
greisinb's Avatar
Mine is etched on to the top deck of the block between cylinders 3 and 5 (that would be the middle two pistons on the driver's side). I'm sure there is a lot of information contained in the number but all you really need are the first 3 characters:
56D 1999 - 2002 4.0 liter w/o Secondary Air Injection
94D 1999 - 2002 4.0 liter with Secondary Air Injection
90D 1999 - 2002 4.6 liter w/o Secondary Air Injection
96D 1999 - 2002 4.6 liter with Secondary Air Injection
Old Nov 13, 2021 | 03:07 PM
Richard Gallant's Avatar
Rover V8 engine numbers are fun - but it is exactly where @greisinb says
Old Dec 5, 2021 | 10:53 AM
RA021226's Avatar
Guest
So, (in smaller type and above the s/n) is "CR9.3711;" below that is "08D36525A."
Where can I find a s/n decoder? Thanks, mike
Old Dec 5, 2021 | 01:39 PM
@mbrown3039 there is not one for engine numbers 9:37 is compression 8D is generally a 4.6. All the engine number lists stop between 2000 and 2002. These engines were in built over 40 years and used in everything from cars to 4x4's. I have never found a list with mine and is a 8D.
Esco4227
Oct 30, 2019 04:09 PM
Lisa Bunch
Mar 2, 2018 10:20 PM
jfall
Dec 10, 2012 12:43 PM
kayaku
Sep 27, 2008 02:02 PM
angasreid
Jan 19, 2007 11:28 AM
