Engine Identification?? I'm not sure which I have
Hi again... I have the '04 Disco II S model with a 4.6l engine.. That engine blew so I had an engine rebuilt and I believe the guy who rebuilt it put in the better/more reliable Range Rover P-38 2003 engine.. I have lost contact info for the guy so I am just guessing I still have the Disco 4.6l engine..
Problem... I replaced my Power Steering pump and Fan belt, but the Fan belt is loose and screaming like a mad man!! I put some shims under the A/C compressor to shut up the belt.
Question... If this is the P-38 engine, would that be why the belt that I bought for the Disco 4.6L? or is my belt tensioner gone bad??
Also where do I find #s on the engine and how do I Identify the exact engine.. Thanks!
on
Any of the 03/04 engines are the same, no better or worse then the other with the exception of some bad 03 engines that were failing do to an oil pump engine.
There are 2 different size belts fro all Bosh engine, you may have purchased one that was designed for a D2 with ACE, or you nay have a failing tensioner.
But to make it clear, P38's did not have a better 4.6 then the 03/04.
Thanks as always discomike..
I did notice on the AutoZone computer that there was a different part number for a RR 4.6L P38 engine from my LR Disco2 4.6L engine.. I do have Secondary Air Injection, but i'm not sure what the ACE is...
Is shimming my A/C compressor a bad idea, or will it do until I replace the Tensioner???
Thanks again as alway Mike...
