Engine Knock??
Old Dec 14, 2008 | 03:11 PM
ryanD2's Avatar
Default Engine Knock??
Hey all, new to the site, here goes. 2000 Dll with just shy of 90k on clock. Meticulously maintianed since i purchased it about 3 yrs ago. Im more than **** when it comes to "hearing things" in any vehicle, but particularly when it comes to mine. Over the last 15k or so i have noticed a kinda knock or piston slap noise in my truck. Worse when cold but thats a given, only makes this noise when you drop the truck in gear, but no load hardly any noise. Its my understanding thses trucks have fairly good bottom ends and its not like a rod knock that gets worse with rpm. Im a tad leary to pop the hood and give it a listen with the stethescope just incase its relly bad. Everything seems to function well outside of hearing this noise. Any Ideas???
Old Dec 14, 2008 | 04:07 PM
Default RE: Engine Knock??
Only idea, don't wait another 15,000 miles to open the hood.
Snoop around a little and then get back to us.
Old Dec 14, 2008 | 04:30 PM
ryanD2's Avatar
What was the deal with the rocker shafts failing? Do they break or make noise, also i read about whatever type of retainer they used when they pulled the dist. from these engines, was prone to failure as well. Know anything about this?
Old Dec 14, 2008 | 06:51 PM
I would lean towards lifter noise, DII's are notorious for that.
Start poking around and find out for sure what it is.
Old Dec 14, 2008 | 07:14 PM
ryanD2's Avatar
yeah ive thought that route as well. but its decieving sound and what gets me is how it comes on when i put it in gear. i would think the lifters would make noise aside from the load on the motor. Would you hapen to know if worn lifters in these motors will be easily read on an oil analysis?
Old Dec 14, 2008 | 07:29 PM
I do not know if a SOS would give you a answer on this or not.
You could try doing a engine flush and see what happens.
As for only doing it when under load...that makes sense since it just started, it will probally get worse with time.
Are you using full synthetic motor oil?
Old Dec 14, 2008 | 07:42 PM
ryanD2's Avatar
Yes always, mobile1 and it prob never goes past 4k. Ive taken note when dropping the oil nothing shiny. I wouldnt say it just started, ive been noticing it more latley. Now i live in Pa which is colder from VA where i just moved from. Kind strange though. the truck sat for a yr while i was in iraq, i never noticed it as much as i do now. That motor has had regular flushes since i have owned it. This change i tried a bit of the lucus in the sump, but the noise stayed the same.
Old Dec 14, 2008 | 07:51 PM
jkid's Avatar
I'm curious what kind of engine flushes and how often? What octane gas do you use? I've heard that you can unplug a spark plug one at a time to take the load of a cylinder and try to isolate or change the noise, that might show a wrist pin or piston slap. Get in there,listenand do some tests, it could be anything.
Old Dec 14, 2008 | 07:54 PM
Did the noise start after you got back from Iraq? Or was it there before?
Old Dec 14, 2008 | 08:02 PM
ryanD2's Avatar
it was there, but not as bad as it is now. the truck was driven here and then but not really on the road. and im inschool now so its gona take some planning to get it home and tear the motor out, or down if its something like lifters.
