Engine misfire
Old Oct 8, 2020 | 07:50 PM
Kadin Wallner's Avatar
Default Engine misfire
I got a check engine light that will start blinking intermittently so I went and plugged it into a code reader to see what I need to do. It says cylinder 3 misfire but it’s running just fine and doesn’t seem to be down on power. I replaced plugs and wires probably about a year and a half ago. I didn’t change the ignition coils but that sounds like a pain. Could I try anything else before changing the coils?
Old Oct 8, 2020 | 08:12 PM
redwhitekat's Avatar
you should change the coils it’s really not that hard and they are cheap
do the pcv mod and clean or replace the purge valve
Old Oct 10, 2020 | 04:27 PM
Daytoman's Avatar
Coils and wires are probably your next step.
carmonalandrover
Mar 11, 2021 08:22 PM
03SilverDisco
Sep 25, 2020 05:41 PM
Macon B. Norris
Jan 17, 2013 01:26 PM
CampCobb
Jul 10, 2009 12:06 PM
xb70valkarye
Oct 23, 2007 12:50 PM
