engine misfire td5 discovery
Old Aug 31, 2008 | 11:08 AM
borntojump's Avatar
Default engine misfire td5 discovery
my discovery td5 has got intermitent engine misfire can anyone help
Old Aug 31, 2008 | 11:31 AM
Default RE: engine misfire td5 discovery
Deisels cant mis fire. They use compression for combustion not spark.
What exactly is it doing?
Old Aug 31, 2008 | 12:37 PM
jkid's Avatar
Bad injector maybe. Is it allthe time, or only when it's first started?They can be cleaned and or tested fairly cheaply. Running some diesel purge through it may help some.
Old Aug 31, 2008 | 12:41 PM
Urban Panzer's Avatar
They can "Misfire" in a term, well "miss" injection if that makes sense and it feels the same as a misfire on a petrol engine
FIRST thing to check is whether or not there is any oil in the ECU harness, the injector loom can fail and allows oil down the harness and into the ecu. I would think this is more than likely your problem
details here of where to look
http://www.discovery2.co.uk/Injector_harness.html
pgaukroger
Feb 29, 2016 05:56 AM
Gromeo
Jan 24, 2013 03:41 PM
clanburns
LR2
Apr 29, 2011 09:51 AM
MLX665GP
Jul 14, 2008 09:10 AM
trini defender
Defender
Dec 11, 2006 05:14 AM
